ONEX #54 Web Site
Date:  1-24-2014
Number of Hours:  0.00
Manual Reference:  B04
Brief Description:  Flight test info
Surfed the web for info/guidelines on generating a flight test program.
A document that explains it all, the FAA's AC 90-89A - Amateur-Built Aircraft and Ultralight Flight Testing Handbook, available here:
https://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentID/23127
A student senior project at Cal Poly's Aero Department with useful forms for each test flight that could be modified for Onex use. Good for focusing on things that need to be accomplished in Phase 1 flight tests.
"Development of a Flight Test Program for a Homebuilt Zenith STOL CH 701" available here:
http://digitalcommons.calpoly.edu/cgi/viewcontent.cgi?article=1085&context=aerosp
Worked on measuring the position of the nose and main gears relative to the "datum" that is 36.5" forward of the firewall.
